Update problems with "mean.vi" from LabVIEW 5.1 to 6.1
Hallo,
I've just recompiled an existing LabVIEW-program which was until now running and programmed under LabVIEW 5.1. Now the programme has to be edited under LabVIEW 6.1. When compiling the not edited programme under LabVIEW 6.1 error messages were shown, which says that a file was not found. After some research I found out that "mean.vi", which seemed to be available under 5.1 was not running under 6.1.
As I'm writing my thesis at the moment I'm looking for an explanation. I think that perhaps that mean.vi was changed during updating from 5.1 and 6.1 and thus the old version does not run any more.
Thanks for your help,
Verena
(2,439 Views)
Hi Verena,
The following is based on my memory alone. Please forgive if I am wrong.
I seem to remeber that the icon layout of the Mean.VI in LV 5.1 and 6.1 changing. There used to be an error output on the Mean.VI that would warn you if it could not perform the operation.
You will have to manually find all of the offending VI's and replace them.
Ben
(2,439 Views)
