02-05-2007 12:23 PM
02-13-2007 09:36 AM - edited 02-13-2007 09:36 AM
Hi Idilio,
When you move a file on windows.
You need reassign the new location on LV project by make a right click on your file and select explore. (or remove and add again the file)
It's the only to reassign the new location.
Message Edité par Christophe S. le 02-13-2007 04:36 PM
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
02-14-2007 03:58 AM
02-14-2007 04:02 AM
IDILIO a écrit:
But when i make a right click on the file and select explore it goes to the Windows explorer, and after that what i should do to reassign the actual file to the project file?
You should choose the file on the new location, and add the file on your project. After you can delete the file with the bad reference.
Christophe S.
02-14-2007 04:08 AM - edited 02-14-2007 04:08 AM
Message Edited by IDILIO on 02-14-2007 04:09 AM
02-14-2007 04:21 AM - edited 02-14-2007 04:21 AM
When you ha a project, you need use sub-directory for :
_ SubVI
_ File for initialisation
_documentation file (*.txt, *.html, or other)
_ help file
_ And other for each document.
When you have this you can select all file in *.txt format, and use drag and drop into you project for add new file.
With this structure for a project, it's more easy to add diferent file on you project.
But we haven't other solution.
Message Edité par Christophe S. le 02-14-2007 11:21 AM
Christophe S.
02-14-2007 04:25 AM
I don't need to add files!
I need to update files!
For Labview files this option is done by doing a rename!
02-14-2007 04:32 AM
Yes, for for a VI this option is possible by a rename, but for an another file it's not possible.
I can suggest to R&D, add this option for a new version of LabVIEW.
Christophe S.
02-14-2007 04:36 AM
Ok
It will help a lot if they create that option.
Thanks Christophe
