Update to IMAQ313: Labview and Matlab hang on startup.
After the update Labview 6.1 and Matlab 6.5.1 hang on startup of a VI that calls on Matlab during execution. It worked with IMAQ 2.5.2 before I updated to IMAQ 3.1.3 to overcome a problem with a DALSA2M30 camera file. Now, labview won't even load the VI.
(2,746 Views)
Can you load subvis that are used by your vi? Have you already tried a mass compile? Can you load vis that use similar functions and subvis? Do you get any error messages?
Please try to narrow down the problem as much as possible (ideally you should find the subvi that causes the problem). Do you see a similar behavior with any example vis that use NI-IMAQ functions? How do you communicate between Matlab and LabVIEW? Is there some (small) example code that you can post here for reproducing the problem?
Jochen Klier
National Instruments Germany
(2,742 Views)
I checked all subvis. They all start fine except the one that has a Matlab script field. I've also created a new vi and only put in one Matlab script. When I tried to save it Labview didn't respond any more and I had to kill the process with the task manager.
(2,739 Views)
Here is a knowledgabe base article that deals with these problems. Please note that these issues are resolved in the LabVIEW 7.1.1 maintenance release.
I hope that helps,
Jochen Klier
(2,736 Views)
