Update value in database(access-connectivity toolset )
I am using the database connectivity toolset and I am trying to change values of an existing database.
I used the "Update" command but i got an ERROR!!!.
"Exception occured in Microsoft JET Database Engine, Syntax error in UPDATE statement..  in Conn Execute.vi->...."????
What to do???
Regard's
Eyal.
(3,848 Views)
Hi
The shearch statement (after Where) shud be anather field than the field you are trying to change.
I am using defoult value on cursor type with sucsess.
I hope this will help you
Rune
(3,831 Views)
I'm not sure about your statements, but you need to have a semi-colon at the end of the query.
(3,825 Views)
try sql query like " UPDATE TBLPASSWORD SET PASSWORD = 'DAVID' WHERE USERNAME='CECAR'  "
(3,817 Views)
