Updating ADC register
Hi There,
From my previous posts, you might know that I am quite regular in this forum. I have managed to solve the problems I encountered with your help. Now Im clueless about what is wrong with my code.
Basically, I am writing a certain data (16 bits long) to an ADC (AD7490) on every -ve clock pulse. But before I write which analog address to choose from, I need to write a dummy cycle to the ADC to set it up properly. this is followed by writing setup data which has the required channel to be selected. I managed to do both of it and I can read the data from the ADC.
But this is only happening once. what I mean is that after I write the particular address of the analog source at the time of SETUP, the ADC is not outputing the correct data when I write another address to it in the same manner as I wrote the initial address. I even scoped the DAQmx pins and saw that the data is written on the correct clock edge and LOAD signals.
why could this be happening? If I write the new address to the initialization case, the ADC will output data from  the new address. but I cannot update the readings from another one if I want to.
can you help me out here please.
I am uploading my code here for your info.
thanks
Labmat.
Message 1 of 1
(2,468 Views)
