Updating Xcontrol Data
Hello Guys.
Hope You can help me with this.
I have an aplication that uses Xcontrol to load data from mysql. Basically each xcontrol has a listbox that loads the primary key(code) of the table and a string field that loads a description for that key, so when the user change the value in listbox it show "whatever" in the string box.
I have made some text and i realized that when I add more "codes" and "descripctions", the xcontrol doesnt update the values even if i close the VI.
It only loads new data when the aplication is started for the first time.
I want to know if there´s a way to unload xcontrol when they are not in use in the current VI.
My aplication has a principal menu with a lot of VI's. I can send some code but not all.
Thanks in advance and sorry for my english.
(2,887 Views)
Add a method to the XControl. This allows you to initialize it any time you want. You don't need to unload it.
(2,863 Views)
Thanks. I have created a Refresh Method and it works just great.
I didnt know about property and methods in xcontrols.
See you.
(2,843 Views)
