09-26-2006 02:08 PM
09-27-2006 02:50 PM
09-27-2006 02:56 PM
"What did I do wrong?"
If I recall correctly, all VI's that use the XControl should be closed when the facade is edited.
Ben
09-27-2006 03:01 PM
09-28-2006 12:14 PM
Just like Ben mentioned, in order to edit the Farcade.vi, all VIs calling it must be closed.
Tunde A.
09-28-2006 12:27 PM
09-28-2006 12:35 PM - edited 09-28-2006 12:35 PM
I've found the same behaviour. It is legal to unlock the XControl while VIs using it are loaded, make changes, and then "Apply Changes to Instances" - but cosmetic changes don't seem to always get propagated. I found that I had to select the XControl on the host VI and replace it with itself (i.e. Right Click - "Replace" - "Select a Control ..." and browse to the *.xctl file) for the changes to show up.
Jaegen
Message Edited by Jaegen on 09-28-2006 10:36 AM
09-28-2006 12:41 PM
Yep, exactly. Except when I tried to replace it LV crashed.
George
09-28-2006 12:45 PM
Ah, the plans of mice and men ...
Well, you could dry deleting it and then dropping it on the FP again (more work though of course, depending on how much is going on on the BD)
Jaegen
