Updating an indicator on the main VI whilst executing a sub VI
I was wondering if you could help me with the following.
I have a sub VI that basically reads a text file and sends it out on the serial port. What I would like to do is update a progress bar (indicating how much of the file has been read/sent) on the main VI whilst this sub VI is running. I would also like to update a text box on the main VI to display the data read from the text file.
I am intending to use the sub VI on other LabVIEW projects so I need to keep it modular.
Which is the most logical way to go about doing this? Passing each control I want to update by reference? Or is there a better way?
Any help would be appreciated.
Matt
(3,646 Views)
Are you using an architecture that allows your top level front panel to update while the subVI is executing?  Do you think you could post an example of your code?
(3,628 Views)
Accepted by topic author mattb-5906
ReferenceMatt
You need to create a Reference to your Main.vi Progrss bar  then use a propertn node in your subvi to update the parent control.
Message Edited by VADave on 03-05-2009 02:11 PM
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(3,627 Views)
jmcbee,
Here are some screen prints of my LabVIEW diagram. Note: these were done for testing hence the the reason for no error checking and the like
See attached files
Matt
(3,612 Views)
Thanks VADave,
I will give it a go. Are references and property nodes still the best way of doing this for the way I've set out my LabVIEW program.
Matt
(3,605 Views)
