Updating data in MS Access
Hi all,
In my program I am sending an array of clusters into an MS access database table using the database connectivity toolkit. What I want to do is, I want to update a particular row in the table or being precise, to update an element of the cluster array. I have checked the examples and seen how to update all columns but there is no information about updating an entire row.
I would be grateful if someone can help me on this.
Nitz...
(3,746 Views)
Plz send me a solution if someone knows..
Nitz..
(3,738 Views)
Hi Nitzy,
I'm not sure I understand your question, but here's my interpretation: You want to update some/all elements of a single record in your database. You do this using the DB Tools Update Data VI; you don't need to worry about the array of cluster after you've INSERT-ed the data.
Perhaps you could post the code that's giving you the trouble.
Jim
(3,729 Views)
Hi Jcarmody,
Thanks for your timely response. You have interpreted my problem correctly. The only thing is that, I want to specify the location (row) into which i want to update the elements. I have attached all my vis here. i am creating a table and entering some data using the db1.vi and then fetching the data from the database and editing it using the dbfetch.vi. In the second vi i need help in updating the elements in the control to a particular row in the table, say 5th row. Can you tell me how to do it..??
Hope i made it clear this time..:)
Nitz..
(3,722 Views)
You need to specify a condition that uniquely identifies the row you want to update; I selected the Name field.  You also should tell the UPDATE function which fields you want to update (not required - read the Help for the Data terminal).  I converted your array to a cluster and changed your Variant to Data from nested For Loops to use a 2D Array of String as shown in the second snippet (not necessarily better, just neater).
Jim
(3,714 Views)
