Updating data in a Word graph (Office 2010) giving error -41105
Hi There
I'm trying to make a MSWord report using a template (.dotx) containing 6 graph objects (index 1 - 6) when updating data in the first graph I'm getting the error -41105 indicating that I need to install Microsoft Graph. I don't understand the reason for that. In an earlier version of my VI I used the insert graph VI with out any problems (except for the tedious work with formatting axis etc.). Does any one know the reason for this error message and how to solve/get around it?
LabView 2011
Office 2010
Best Regards
(3,598 Views)
Hi GaiusMarius,
The reason for this error is that the Graph component probably is missing. Which version of the toolkit do you have installedÖ
Following is taken from here: http://zone.ni.com/reference/en-XX/help/370274E-01/lvoffice/rep_gen_error_codes/
Verify that the MS Graph component is installed on the computer.
Eirikur Runarsson
(3,586 Views)
Hi Eirikur
Thank you for the feed back.
Running Windows 2007, Office 2010. MSGraph is installed and I'm running LabView 2011 PDS with the report gerenation tookit that comes with this version.
I have worked a little further and found when using the "Insert Word Graph" vi, I get an graph object. I then uses this object and copy it to the template, make the necessary alterations (format, fonts, size etc.), eventual make mutiple copies of the graph object in the template with different titles, scales etc. I save the template and when I use this template and the "Update Graph Data" VI the graphs updates as expected. Hmm
Hereafter a new problem occurs: When inserting a logo i the header of the template, the MSGraph error reoccur - what is the connection here?
/GaiusMarius
(3,579 Views)
Dear all,
May I ask a stupid question?
How can I access the Microsoft office standard page to verify that the MS Graph component is installed on the computer?
I am using MS office 2019.
Thank you in advance.
Plu
(1,416 Views)
