Updating from LV 4.01 to Lv 5.1
I updated labview 4.0.1 to 5.1,and mass compile the programs to this version. When I tried to run again my programs in LV 5.1 I got the message " Program stopped at CIN 0x190 InitVXIlibrary_old.vi"
What do I need to do to fix this problem?
do I need to use the 4.0.1 VXI libraries in the newer version??
(2,486 Views)
The reason you got the error message is that the object code got dumped when the CIN was recompiled in the new version. The solution is to use the VXI drivers for LV 5.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,486 Views)
