Updating one boolean array element conditionally
Hi, I have a 16 bit array of boolean values, and I want to be able to change one bit, and only one, when the appropriate input to the VI changes.
As background, I have a 16 bit port expander (I2C) and I need to change just one bit, ie set one of the outputs on or off, without affecting the others. To do this, I read back the 16 bits so I know what the current states of the outputs are, then I need to change one bit, and write the 16 bits back in.
I looked at the Replace Array Subset block, which seems to be related, but since I only need to change one of the bits at a time, I dont see how I can connect up controls to all the 16 bits and modify only the one I need to change.
Is there an elegant way of doing this? For example can I have a combo box with the names of the ports in it, so the user can select the port they need to change, and then they set the state of a toggle switch or boolean value to set the bit, and only that bit? Thanks for any advice.
(7,258 Views)
Accepted by topic author TripleAntigen
Is this the sort of thing you had in mind?
(7,254 Views)
Brilliant! Exactly what I needed, thanks. I think my understanding of the Replace Array Subset block was flawed.
Much appreciated.
(7,249 Views)
Could you please advise how to change square type boolean array to be round type programatically? Thanks for answer
(7,078 Views)
Hi arifi,
can you tell us why you want to do that "programatically"?
(Answer: You need to use LV scripting to change VIs programatically…)
(7,067 Views)
actually I want to replace the round type boolean array other size or shape. Is it possible to copy and paste during runtime?
(7,019 Views)
Hi arifi,
at runtime you cannot edit a running VI: so the answer to your question is "NO"!
But there are surely options to reach your goal: you might use picture rings or the 2D picture indicator instead of boolean arrays…
(6,996 Views)
