Updating row header strings of a main VI table indicator simultaneously from the subVI.
Hi, I am trying to update the row header strings of a table which is present in the main VI from the SubVI.i want to update the row headers
simultaniously as the sub vi runs.I have used control Reference and a property node(Value) but i dint get the result.Please find the attached VI.
Please give me the solution.Thank you.
(2,672 Views)
for table control you have direct property node - Row header strings ,
Why are you using value property node.
(2,663 Views)
i am also using row header string property node i am getting the data in the main VI after sub VI finished the execution.I want update it as sub VI starts execution.
(2,660 Views)
That's called dataflowSmiley Wink
use your property node on the block diagram of main VI, create header first and then pass other elements in Table.
(2,648 Views)
