Updating sbRIO software
Could you post the output of running "ipconfig"? If I'm understanding your images correctly, you can see the sbRIO in MAX, but not configure it, which suggests that there's still something wrong with your IP configuration.
Message 11 of 26
(2,814 Views)
Running ipconfig gives me...
Windows IP Configuration
Ethernet adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Wireless Network Connection 3:
Wireless LAN adapter Wireless Network Connection 2:
Ethernet adapter Bluetooth Network Connection:
Ethernet adapter Local Area Connection:
Link-local IPv6 Address . . . . . : fe80::8501:8b75:fe23:4bf0%12
IPv4 Address. . . . . . . . . . . : 192.168.12.34
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.12.1
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : dynapower.com
Link-local IPv6 Address . . . . . : fe80::a0c5:a3d7:46db:f52a%11
IPv4 Address. . . . . . . . . . . : 192.168.9.35
Default Gateway . . . . . . . . . : 192.168.9.1
Tunnel adapter Local Area Connection* 14:
Tunnel adapter isatap.dynapower.com:
Tunnel adapter isatap.{4751ADDA-03EB-4874-9B15-7B307D0ABA35}:
Tunnel adapter isatap.{23FBF3E8-B6CA-435B-81A9-F89474454492}:
Tunnel adapter isatap.{E49058FB-6EBE-40C4-B1EE-A5198CD92354}:
Tunnel adapter isatap.{404FECF9-A854-4966-BEF6-3F16854F4DDB}:
Tunnel adapter isatap.{454AACB0-3908-4E0B-9766-1D38C450FA1E}:
Message 12 of 26
(2,810 Views)
Can you do a "tracert 192.168.12.33" (the IP address for your sbRIO) and see if that works? It should, if ping works. I would also remove the default gateway of 192.168.12.1, since I assume there isn't actually a gateway on that connection. Is there anything else on the 192.168.12.xxx connection? Is it possible you have a second device on that network that's configured for the same IP address as the sbRIO, or is it a direct connection to your laptop?
Also I'm a bit confused since you show images with the sbRIO configured as both 192.168.12.33, and as 10.0.0.2 (although I'm guessing in the latter case you weren't able to save those settings).
Message 13 of 26
(2,805 Views)
I deleted the default gatway. When I tried tracert, I got...
Tracing route to 192.168.12.33 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.12.33
Trace complete.
And sorry for the change in IP from my images. I was working with IT and that was an open static IP that they supplied me with to try to get a connection. Also, as far as I am aware, there is nothing else on the 192.168.12.xxx connection. The sbRIO  should be the only thing with that 192.168.12.33 IP address, and it's connected directly via crossover cable.
Message 14 of 26
(2,801 Views)
I'm out of ideas, then. I would expect it to connect properly with both your laptop and the sbRIO configured on the same subnet through a crossover cable and with no other network interfaces enabled.
Were you able to reset the sbRIO using the instructions Spex provided?
Message 15 of 26
(2,786 Views)
I reset it using those instructions, but I still run into the same issue.
Message 16 of 26
(2,781 Views)
When you reset it, it should reset the IP address - does that happen? If not, complete the sequence to the point where you're back to a link-local (169.254.x.x) or 0.0.0.0 (depending on your sbRIO model) address.
Message 17 of 26
(2,778 Views)
Yes. When I reset it, it reverts back to the 169.254.4.42. And when I have my laptop set to obtain IP address automatically, it recognizes the sbRIO is connected, but I still can't view installed software and continue to receive the inconsistent IP settings message.
Message 18 of 26
(2,762 Views)
What if you assign your laptop a static address in the 169.254.x.x range (with the netmask set to 255.255.0.0 and no gateway)? That's what I've always done for initially configuring an sbRIO.
Message 19 of 26
(2,758 Views)
I just tried that, (I set my IP to 169.254.4.43 and netmask 255.255.0.0) and I'm still getting the exact same thing.
Message 20 of 26
(2,748 Views)
