Upgrade a legacy DAQ
I'm upgrading a system that is using a NI cDAQ-9172 with NI 9211 and 9213 modules.
From what I can tell, the modules will work with the latest LabView, but the chassis will not.  Is there an updated chassis that will work with the older modules?  Thanks in advance.
(546 Views)
https://www.ni.com/en-us/shop/model/cdaq-9178.html
The 9178 should work as long as the modules are still supported. You could also get a 3-slot chassis if you only have to modules.
(541 Views)
Thanks!  (We have 6, so the larger one is perfect)
(537 Views)
This link is useful for checking if you have not seen it before
https://www.ni.com/en/support/documentation/compatibility/21/ni-hardware-and-operating-system-compat...
(525 Views)
