Upgrade failue: LV7 reading of LV6 1D array of waveform data fails (#116)
I am upgrading a program from LV6.02 to LV7. I have written a 1D array of waveform data to a file and when I attempt to read it under LV7, an error 116 is generated. Data can be read an written within the same version, but not across versions. I attempted to use a cluster that looks like a LV6 wavefrom, but to no avail. Any suggestions?
(2,591 Views)
I believe what you are running into is that the datatype "waveform" is different between 6.0 and 7.0, so there is a type mismatch between the version. The timestamp in LabVIEW 7.0 is different than 6.0 so I would suggest creating your own "waveform" in 7.0 that is the same as a 6.0 waveform and see if you can get it to work.
(2,591 Views)
Evan, thanks for the suggestion. Unfortunately, that does not work. NI's only solution so far has been to re-write the data, in LV6, as a cluster, instead of a waveform. Then re-write again in LV7 as a waveform. A better solution, which requires knowing the LV6 binary file waveform structure, would be to create a new VI to do the task. Unfortunately, I do not know the internals.
(2,591 Views)
Hi Blubell,
Checkout this link. It will get you started.
http://zone.ni.com/devzone/conceptd.nsf/webmain/370DFC6FD19B318C86256A33006BFB78?opendocument#3
If you come up with a conversion utility, please post.
(It takes a brave person to wonder in these woods.)
Ben
(2,591 Views)
