Upgrading LabView from 2014 to LabVIEW 2016
I have labVIEW projects from version LabVIEW2016 but currently I have the oldest version (LabVIEW 2014 ), so I cannot open my projects. Can you help me with this, please
(1,820 Views)
Hi nalnaim,
You need to downconvert those VIs from LV2016 to LV2014 using LabVIEW2016 (or newer).
When you need help with that you should post your VIs in the VersionConversion thread!
(1,819 Views)
Thank you for your suggestions
Can you advice me how to upgrade my old version LabVIEW2014 to LabVIEW2016, please?
(1,804 Views)
You can use  https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion for Conversion.
Make sure you are not sharing a .zip file with N Number of Individual Modules inside.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,779 Views)
Hi nalnaim,
Install LabVIEW2016 (and everything else you need), then activate LabVIEW using your license/serial number…
(1,771 Views)
