Upgrading to LV 2017 from LV 2015 causes a dramatic slow down in application execution speed
I recently upgraded to LV 2017 17.0f2 (64-bit) from LV 2015 15.0.1f10 (64-bit). Noticed a remarkable slow down in execution speed of an application I originally developed in LV2015. Any Ideas why? A bit disappointed as I expected newer versions to better/faster or atleast as good as the previous ones. To put things in perspective, a loop which used to run every 140 ms now takes 280 ms!!
[BADGE NAME]
Message 1 of 12
(3,534 Views)
That's astounding!  Can you isolate the loop and let us take a look at it?  A 5-10% difference I could (maybe) understand, a factor of 2?  Not so much.
Bob Schor
Message 2 of 12
(3,523 Views)
I can't say I saw a massive performance degradation with 2017. Can you isolate which function(s) in the loop are slower after the update?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 3 of 12
(3,520 Views)
Agreed. Strange to me too. Unfortunately this is one of those loops I definitely can’t share 🙂 and it’s quite involving so I am painstakingly looking at every vi, node, method etc within  that loop. Will let you know when I find it. In the meantime I was hoping anyone knows something about possible LabVIEW, windows settings ( something specific with the LV 2017 64-bit? Etc etc.
[BADGE NAME]
Message 4 of 12
(3,479 Views)
Are you dynamically calling VI's from a path? If so the editor could be trying to recompile them each time they're opened. (That's not a 2017 thing, that's a "new version" thing).
Message 5 of 12
(3,472 Views)
OK. At which point Would it then stop re-compiling every time then? Would a mass compile nake a difference?
[BADGE NAME]
Message 6 of 12
(3,464 Views)
I'm not the best person to answer that, but I think they'd have to recompile each time you call them until you save them. A mass compile should update them to the current version and you should be OK.
(Just a guess on my part... hopefully if I'm wrong someone will correct me.)
Message 7 of 12
(3,460 Views)
You don't mention any timing VIs, but the symptom of a perfect doubling of the loop rate sounds like a metronome function.  If you place a metronome set to 140ms and your code runs 130ms, your loop timing is 140ms.  If your code now runs 10% slower at 143ms, then your loop rate jumps to 280.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Message 8 of 12
(3,444 Views)
I have confirmed that this is not a LabVIEW issue. It’s a windows system issue. So for those out there who say  “That’s why I don’t upgrade” etc etc. There is nothing wrong with updating. LabVIEW 2017 works fine 🙂
Thanks guys
[BADGE NAME]
Message 9 of 12
(3,403 Views)
OK, so that begs the question.... what actually caused your differences in timing? Which kind of "windows system issue" was at fault?
Message 10 of 12
(3,399 Views)
