Upload LIFA_Base error
Hi
I'm working with arduino for the first time and I ran into a problem on the very first steps. I did connect my arduino mega 2560 with my pc. I checked out NI max and it shows under devices. Next I did open the LIFA_Base.ino file located at c:\program files\..... When it opened I checked that the right serial port and the board I use was selected. Then I tried to upload LIFA_Base to the arduino, but here did it go wrong.
When the uploading starts it says "busy compiling sketch" and after one/two seconds it says "problem with compiling". I think I did all steps correct from the instruction videos I saw.
Is there someone who can help me with this problem?
Kind regards
Ruts
(3,157 Views)
Accepted by topic author RutsT
Problem is solved. I just had to update my arduino software from v1.0.3 to v1.0.5
(3,129 Views)
