Uploading Startup Application to NI 9058 using NI MAX 2024 Q1
We are using Crio-9058 Chassis and trying to update the Start up application using NI Max. We have made minor changes to the RT Code and generated a CDF file however, we are getting a pop-up to format the Crio.
The same setup was is also replicated using Crio-9055 and NI Max 2018 which seems to work perfectly fine.
(537 Views)
Accepted by topic author linu95k
PKG installation was introduced in 2020 to replace the legacy CDF. See Software Installation Options for NI Linux Real-Time Controllers and select legacy installation. However, the last supported CDF driver is 2020. NI MAX 2024 might not support CDF installation at all.
https://tmesystems.net/
(517 Views)
