Urgent!! Run application without installation of runtime
I need to run a LV 7.1.1 application on another computer. I could not install the application or the LV runtime engine because my user account on that computer does not have sufficient right. Does anyone know a way to include all necessary runtime components with the application that does not require an installation? The application is purely software and does not use any hardware devices (not even serial communication). The targe computer is win2k or xp.
Any help will be greatly appreciated!
-Joe
(3,425 Views)
I haven't tried it in a while but you used to be able to just put the run-time engine in the same folder as the exe. Can you burn a CD and try to run it that way?
(3,413 Views)
Dennis, can you explain a little bit? The runtime engine in lv 7.1.1 is an installer.
-Joe
(3,401 Views)
He's talking about everything (all files and folders) in ...\Program
Files\National Instruments\shared\LabVIEW Run-Time\7.1
"Joe Guo" <x@no.email> wrote in message news:190843@exchange.ni.com...
> an installer.<br><br>-Joe
(3,396 Views)
Dennis and DD, thank you guys! I was able to make the package without the runtime installer, needless to say the total size is much smaller as well.
-Joe
(3,353 Views)
Hi Joe:
Could you elaborate on how you did it?  Did you copy all the contents of the LV Run time from the shared folder into your application?
(3,110 Views)
