Urgent : needs help on packaging
Am new to LABVIEW8.0.
I have developed an application and its working fine when i run the VI file. when some particular item from a menu in the front panel was selected some specific pictures have to get loaded. when i run that VI file its working properly and the pictures displayed accordingly. But when i created an exe file, the images were not getting loaded. shall i get some help regarding how to package a VI file which contains lot of pictures to get loaded on some selection in the front panel. I need some more information on packaging.
Earlier reply was much appreciated.
Mathan
(3,157 Views)
Are you trying to use relative paths to get to the image files? Can you post your code?
(3,151 Views)
hi
actually am working in a concern. my colleague developed that application and he is no longer here. i just learning LABVIEW now only and don't know much in packaging. i don't have any idea about that relative path you mentioned. please give me some more suggestion. please send me general procedures of packaging.
please understood that i can't able to give that codes without permission.
waiting for your earlier reply.
Mathan
(3,132 Views)
hi
Mathan
(3,129 Views)
Please include your images in your project and also include them as support files when you build the executable.  Please take a look at the following links.
Building Stand-Alone Applications
Distributing Applications with the LabVIEW Application Builder
(3,088 Views)
