Usage of Events over Case Structure
I want to Know what are the advantages if using Events over case strutures.
Is memory useage less in case of events.
With regards,
Suresh Thangappan
Suresh Thangappan
(2,529 Views)
Hi Suresh
I think you can't just compare these two structure types, as they have a different purpose.
I assume you're about to create an application, so I'd suggest you to study the producer consumer design pattern. There are both of these structures used to separate program-logic and reaction to user-inputs.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,519 Views)
Hi Suresh,
There actually was some good discussion about the relative merits of Event Structures and Case Structures at this post: http://forums.ni.com/ni/board/message?board.id=170&message.id=133228&requireLogin=False.
Take a look at what our posters had to say and post if you have any futher questions!
Good luck!
Megan B.
(2,497 Views)
