Use 32 bits dlls and Labview 64 bits...
I have two devices to control.
One is controlled through 32 bits dlls and one by 64 bits dlls.
So, my question is: what is for you the best solution to explore knowing that each kind of dll are not available on the other version?
Is it possible to build stand-alone executable files from the 32 bits version of LabVIEW and call these exe files from LabVIEW 64 bits?
Best regards.
(2,894 Views)
Yes, a separate exe would work, depending on how much communication you expect to perform. That exe could also include a tcp/ip part in which case you could send/recieve commands, which is neater solution if you expect to do more than 1 call/minute. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,888 Views)
