Use Access database to Load a Pict Ring
All,
Is it possible to load a Pict Ring with a *.png file that I access from a database?
I believe there are two taks being described:
Task 1 is to get from the database the name of the *.png file
Task 2 is to take that file and use it to populate a Pict Ring.
I can load the Pict Ring from the clipboard, but the customer wants to be able to load different images.
LabView 2011 RT
can it be done?
Carmine
(2,710 Views)
Hi Carmine,
According to the Help file for Picture Rings, you must copy a picture to the clipboard to bring it into a Picture Ring.
LabVIEW 2011 Help: https://www.ni.com/docs/en-US/bundle/labview/page/adding-picture-items-to-ring-controls.html
However, I did find this example that programmatically puts a picture on a clipboard. It may be a good starting place for your application.
Example: https://forums.ni.com/t5/Example-Code/Export-A-Screenshot-Of-A-Graph-Chart-Front-Panel-To-The/ta-p/3...
Good luck on your project!
Alexandra Valiton
(2,680 Views)
