Use C++ class within an .so file
Hi everybody ! 🙂
Today, I'm trying to use a .so file within Labview.
I already have the source code in C++ (not written by me), containg C++ classes, struct, functions... I compiled the project with success with the gcc toolchain provided by National Instrument and generated the corresponding .so file. However I fail to reach shared object functions within Labview. I think the problem is due to C++ classes, I read some documentations about the adding of some parts of code like "extern "C"" in case of C++ classes, however all things I tried not provide any result...
So, I would like to know if a documentation about the integration within Labview of a .so file containing C++ classes is existing ?
(I precise that I have already done an integration of a very simple .so file with success (but without classes))
Thank you for your help !
Afghow.
(4,351 Views)
Basically you need to write a second shared library that wraps your c++ objects.
Have you done some googling? That should have given you this:
https://lavag.org/topic/9232-c-classes-from-lv/
http://labviewwiki.org/DLL/shared_library.
The second half in the last link shows what you have to do in principle.
Rolf Kalbermatter  My Blog
(4,304 Views)
Hi !
Thanks for the second link, I have wrapped my C++ classes with success, however I have some problem of calling within Labview. Everything works fine when a class is not dependant to another. But in my case I have an architecutre like that :
class A{
   //Bla
class B{
   private: A;
So when I want to construct an object of the class B, I have a crash of the LabView application. I think that the constructor of class B tries to call the constructor of the class A, but not the wrapped constructor. So, I don't see how to solve this problem without modifying the implementation of methods of classes, which will break the principle of a "wrapper". A wrapper just has to be a layer and doesn't have to modify the implementation.
I don't know if my explication is clear 😕
So, do you have some trick to do within the wrapper class file or a tutorial about this ?
Afghow.
(4,258 Views)
Since class A is a private member in class B your constructor for class B has to somewhere explicitedly new() class A, doesn't it? so why would that crash? Is your class A in yet another DLL that is not available?
(4,247 Views)
That's that, the class B constructor calls the constructor of the class A through an initialization list. So, for you the problem is not located here ?
My class B try to access to a /dev node, maybe the problem is here. I have tested with a sample main where I have the same /dev access using same functions which are present is the so file and it's working fine.
Maybe the combo of LabView and Linux module access is the problem ? I'm lost but I'm searching, if you think having some clue, let me know.
Thank again for your reply,
Afghow.
(4,233 Views)
LabVIEW simply calls the shared lib using dlopen() and dlsym() so a proper test case would be to create a main() program that does this with your wrapper shared lib.
(4,228 Views)
It's what I did and I have a segmentation fault when I'm calling the constructor of the class, and it's what it makes crash the LabView program.
I've applied the classic method to wrap the C++ class, I don't know where the problem could be. Moreover debugging this on the MyRIO board will be hell.
I continue my researches, if you have some clues...
Afghow.
(4,194 Views)
