Use CRIO 9004 with NI USB 8473
I have a CRIO-9004 module and a USB 8473 interface.
I have 2 VIs - 1 for CRIO (FPGA VI) and the other for communication on CAN using NI USB 8473. I want to do both operations at the same time as there is a data exchange between the two programs. How do I combine the 2 VIs? The data on CAN has to be used to manipulate the Analog outputs on CRIO. Can I have one VI to do both jobs? A Real time VI does not support 8473 functions
Message 1 of 1
(2,390 Views)
