Use Griffin PowerMate in LabVIEW?
Hi JeffG,
Can you post your VI?
How did you get it to work in LV 8.6?
The VISA Driver Wizard just gives me the error because the device reports that it is only USB 1.0, but the Driver Wizard needs 1.1 or 2.0.
Brian Smith
Advanced Light Source
Lawrence Berkeley National Laboratory
Message 11 of 20
(2,149 Views)
Hi JeffG and BVSmith,
It is important to know that the drivers for Windows XP and Windows 7 are not the same.  The architecture of the OS's are different and require different drivers.  It is possible that the Windows 7 drivers from PowerMate report that the device is USB 1.0 instead of 1.1+.  Or, the Windows XP drivers report it as USB 1.1+ instead of 1.0.  Looking at the website, it doesn't specify what USB spec it is (http://www.griffintechnology.com/products/powermate)
Che T.
Message 12 of 20
(2,131 Views)
No, I have Windows XP and it is reporting that it is USB 1.0.
JeffG says he got it working in Windows XP, where I cannot because the VISA Driver Wizard won't let me (it being  USB 1.0).
I would like to see JeffG's VI so I can use it too. I don't have a solution for him and Windows 7 😞
Brian Smith
Message 13 of 20
(2,129 Views)
Did you get the PowerMate working in WinXP or Win7?
Message 14 of 20
(1,732 Views)
No, I gave up long ago 😞
We only use it with its driver that produces keystrokes when rotating, pressing it.
Brian Smith
Message 15 of 20
(1,722 Views)
Thanks.  For your solution, the amount of keystrokes = the distance that the knob has been turned, correct?
Message 16 of 20
(1,709 Views)
Yes, one character per "step".  I can't remember how large (fraction of a turn) a "step" is.
You can also send a character when it is pushed down, and pushed and turned, etc.
Brian Smith
Message 17 of 20
(1,700 Views)
Excellent.  I bet the number of keystrokes per rotation (i.e. the "step" size) can be set in the PowerMate configuration ("sensitivity"?).
Looks like this is the one to buy.  Thanks!
Message 18 of 20
(1,690 Views)
Glad to help!
Brian Smith
Message 19 of 20
(1,681 Views)
A few lessons that I've learned.
The powermate keystrokes always set a ScanCode of 0 (since they are not actually keyboard presses).  This is helpful if you map the powermate to a key like "PageUp" and but still want normal "PageUp" functionality if the user presses it on the keyboard.
There is some lag if you use the F keys (like F22) and don't discard the key press.  This is a problem if a .vi or block diagram window that doesn't code intersepting the key strokes is active when the knob is turned.
If your powermate code is located in one .vi and you would like that code to respond to the knob even if another .vi has focus, you can dynamically register for events on the other subvi :
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/dynamic_register_event/
Message 20 of 20
(1,660 Views)
