Use IBIC for a program
Apparently, you can install a BASIC program on the IBIC platform. It is hinted that there are subroutines available that make the program actually work. Where are these subs? Are they DLLs? What are there names?
Thanks Warren Sanders
(3,462 Views)
I found this page [broken link removed] with some links to using various flavors of Basic and NI-GPIB. Hope this helps.
p.s. You posted to the LabVIEW forum. NI has a GPIB forum where you might have better luck posting in the future.
(3,462 Views)
Hi Warren,
There are some links at the bottom of the page mentioned by Dennis that will direct you to the specific Language Interface for your Visual Basic application. Examples are also provided on those pages. Hopefully that will give you a good start.
Best of luck!
Kileen Cheng
(3,462 Views)
