Use LabVIEW to check Duplicate values in SQL
I am trying to use LabVIEW Database Connectivity tool to Execute a SQL Query to check for duplicate values in the table.
But I am seeing this error -2146825023 after the Database Fetch VI is executed.
Looking for some guidance.
Thank you.
(1,843 Views)
The information is really not enough. The error code is not a labview error code. It is an error from the ODBC Connector. I'm missing ... - which database and which connector you are using. - the database structure - your code (at least the SQL command) - the complete error message last but not least: this is a labview forum and not a forum for SQL.
(1,819 Views)
adErrItemNotFound 3265 -2146825023 0x800A0CC1 Item cannot be found in the collection that corresponds to the requested name or ordinal.
ErrorValueEnum - ActiveX Data Objects (ADO) | Microsoft Learn
Qestit Systems
Certified-LabVIEW-Developer
(1,755 Views)
