Use LabView 2020 to work with mxDAQ 17.5
My board is cDAQ-9172. So the latest driver for it is mxDAQ 17.5. However, mxDAQ 17.5 could only be run with LabView 2017. So, is there any method I can run 17.5 on LabView 2020?
I cannot download LabView 2017.
(1,142 Views)
Nope.
You need to get a copy of LabVIEW 2017.
Do you have an active SSP license?  Your probably do because if you purchased LV 2020, then you should have gotten a year of support with it.  If you have a problem downloading LabVIEW 2017, contact NI support.,
(1,111 Views)
Alternatively, you could upgrade to a cDAQ-9178.  For ongoing support reasons, I would upgrade my equipment.
(1,081 Views)
