Use Previous Element of an Array instead of Zero
I have a pretty simple task, I'm trying to make an array of 10 random numbers from 0 to 5. However, if a 0 is given from the random number generator, I want it to use the previous array element instead.
This seems to work if the random number type is "Random Number (Range) I64" but it doesn't work if it is "Random Number (Range) DBL". Why is this?
This can be seen in the example VI I uploaded.
In my actual program, it seems to work intermittently. I'm having trouble figuring out why.
Message 1 of 8
(2,027 Views)
Accepted by topic author downerdce
The odds of getting exactly 0 from a Double is practically 0.  The odds of 0 for an integer are 1/6.
Message 2 of 8
(2,021 Views)
Makes sense! My actual program I'm using this in also is using double's. I will try a threshold value instead.
Message 3 of 8
(2,014 Views)
By the way, you can greatly simplify your VI using an Autoindexing tunnel to build your array and a Feedback Node (or Shift Register) to keep the previous value.
Message 4 of 8
(2,013 Views)
thank you! Can you do the same if you are referencing a previous iteration of the array with that type of shift register (feedback node)?
Message 5 of 8
(1,998 Views)
I'm not sure what you are asking for here.  A Shift Register and Feedback Node will just return whatever the previous input to it was.
Message 6 of 8
(1,982 Views)
When you're doing this to get the value from previous full iteration of a FOR loop...
Message 7 of 8
(1,975 Views)
Nobody here would be doing "this". (attaching a truncated meaningless picture of useless code!)
  • Why is the shift register expanded to two histories?
  • Why is it not initialized?
  • What should happen if the first random value is zero (i.e. if there is no "previous element"?)
  • Why does the shift register contain a Boolean instead of the previous random number?
  • Where do all the wires come from and where do they go?
  • Where is the rest of the code?
  • etc.
Please attach your VI if you want to get help!
Message 8 of 8
(1,968 Views)
