Use RT Communication Wizard to build application for PDA
I am wondering if the RT Communication Wizard can be used to build the Host, NPL and TCL VIs for PDA touch screen pocket PC model NP 606S.
I am familiar with using RT Communication Wizard to build RT set of VIs for communication between PC and cFP-2020 field point.
Now I need to go step further and develop the similar VIs, one VI (NPL along TCL) that will run on the RT Target (my field point) and Host VI that I will compile and run from PDA (NP 606S). I am using cross-over Ethernet cable (TCP communication).
If this is possible to do, are there any special instructions (rules) to complete the process properly.
Thanks in advance,
Peja
(2,720 Views)
I don't use the RT comm wizard, but after generating a small sample program, my answer would be yes. The RT part is only on the RT side. Programs written using the PDA module use the TCP VIs just like regular programs and I have used them to talk with a FP, so it should work. You should keep in mind that the display on PDAs is limited (no clusters, no arrays and so on). Since, according to this, the NP 606s isn't a PDA, it's possible it will be able to display them (although I doubt it).
___________________
Try to take over the world!
(2,712 Views)
