Use System Exec IrfanView to open JPEG file
I am trying to use System Exec to call Irfanview to open a Jpeg file, and the following error occurs:
"Error 2 occurred at System Exec.vi. Command was "iview32 c:\test3.jpg /hide=3 /pos=(30,30)"
"LabVIEW: Memory is full."
"NI-488: No Listeners on the GPIP"
I then tried to add "cmd /c" in front of the command but the DOS windows just flash open and close and then nothing happen.
I have no problem opening the jpeg in DOS command window.
Anyone can help?
(4,046 Views)
did you try to give the full path to 'iview32'? (as in 'c:\program files\iview32\iview32.exe' (I'm just guessing at the actual path information, you'll have to find the real path))
(4,037 Views)
Accepted by topic author splee
you do not need to specify the full path as long as you have the path in your path variable
I think the problem may be that you are using the wrong program name I think it is i_view32 not iview32
- James
Using LV 2012 on Windows 7 64 bit
(4,023 Views)
The name "i_view32.exe" is the correct executable name. However, the path will also be dependent on the bitness of the OS. If installed in the default directory, this will be "C:\Program Files (x86)" on 64-bit operating system.
(4,009 Views)
At least on my system I also get error 2 when I don't specify the path. I think IrfanView does not add its installation directory to the path variable so it is not found when only providing the exe name.
(4,002 Views)
Oops!!
(3,996 Views)
