Use a 1D array to store data to logfile
I am working on a project where I want to read the digital inputs to measure the inputs and detect if a pin is set to high (except for pin 7, 9, 11 and 13 which are the opposite). It works as it is done now, but I am using a 2D array in order to write to a text file except that I actually only need 1D array for my purpose. The first part of the design instantiates the array with all 23 rows set to OK. Then it enters the while loop and when a high  pin is detected, the OK row for the corresponding index is replaced with an error string.
My question is how I can achieve the same thing by only initializing a 1D array and then replace the the row as the while loop is executed?
I am new to the LabVIEW world, so please be nice 🙂 Thanks.
(4,338 Views)
I don't know what a ".gvi" file is but simply changing the extension to ".vi" LabVIEW still can't open it.
=== Engineer Ambiguously ===
(4,261 Views)
gvi is probably NXG.
mcduff
(4,259 Views)
Hi sallo_93,
Its good to see you using NXG!
I've just looked at your code and have quickly made a more simple version of it. (although may need some changing) The reason being just to show easier ways to initialise an array ect.
I am still not quite sure what you are looking for. However I have used 1D arrays in my code. Let me know if this is what you were looking for.
(4,246 Views)
Hint: There is a "LabVIEW NXG" tag directly below the name in the first post.  Expect to see more of those over the years.
(4,242 Views)
NXG should have it's own board as now we have two incompatible programming languages sharing one board.
(4,230 Views)
