Use buffering and psp with datasocket-VIs and without any binding and shared variable node
I'm using LV 8.5.
I'm trying to develop a multiplatform (windows and mac os x) and multi-computer application. II want to get executables running on each device, communicating through the network. Communication process includes datas (such as images) and events messages (something like "Hello, I got an error" or "youyou, my work is done" or "I'm hereeeee!!!!...."). I do need a communication without any loss of data.
I worked a lot and wanted to test a psp-based design, without any binding nor shared variable node (mac os...) using data socket VIs and SVE buffering.
I managed to :
- deploy shared variable library dynamically (even in an executable)
- communicate between two PCs with datasocket VIs
However, I never managed to enjoy buffering (even locally with one VI doing the deployment and writing datas and another one for reading).
I worked hard (dynamic buffering setting, dynamic buffering watching like in  http://zone.ni.com/reference/en-XX/help/371361D-01/lvconcepts/buffering_data/ and in the example "DS send image" and "DS receive image" in the labview examples, trying to use "?sync=true" in the URL, etc...) but no way to get things work.
I attached a jpeg of an example of receiver and sender. I use wait commands in both receiver and sender to test buffering
Receiver do receive datas (the last written) but buffering doesn't work.
Did somebody did that before ? (better than me...)
Bo
(3,005 Views)
Indeed my problem has been solved. My error : in the While loop of the receiver VI, I always reactualize the PacketsMaxBuffer and OctetsMawBuffer parameters, what resets the buffer and make it appears ineffective.
I now set
the PacketsMaxBuffer and OctetsMawBuffer values only once at the begining of the VI and the psp buffering works perfectly.
Sorry for the desagreement...
Bo
(2,958 Views)
