Use column in 2d array as page number for 3d array
You can simply sort them after the fact. I would suggest getting the OpenG Array library, as that has a VI for sorting 2D arrays. To still use the 3D array you would need to correctly determine the number of rows, which is the largest value from the available plots. For example, if plot 0 has 3 XY pairs, plot 1 has 5 XY pairs, and plot 2 has 4 XY pairs, then you would want 5 rows.This means counting the number of instances of "0", "1", "2", etc. in column 1 ahead of time so you know what value to feed to the Initialize Array function.
Using the 1D array of clusters isn't all that complex:
Message 11 of 12
(959 Views)
Here's my opinion.  I borrowed the cluster idea from smercurio_fc, but processed the result into a padded 3D array.
Note that this assumes that the lowest page number (from the first column in the original 2D array) is always zero.  (fwiw, ymmv, eieio)
Message Edited by jcarmody on 03-11-2009 11:57 AM
Jim
Message 12 of 12
(954 Views)
