Use custom .ini file in .NET build spec
Does anyone know why we can define a custom configuration file in an EXE but not in a .NET Interop Assembly?
Any way to use a custom ini file? So far the only way I can think of is use a post-build action, which seems overkill.
(4,632 Views)
Hi Jim,
I think I found a related previous post and knowledge base article about using config files with executables containing .NET assemblies.  However, this could count as a post build action, since you have to manually put in your own config file.
Patrick B
(4,572 Views)
