Use mouse scroll wheel to change numeric control
Mine is a snippet that you should be able to drag from your browser onto a block diagram and have automagically converted to code.
Jim
Message 11 of 21
(1,361 Views)
jcarmody, that would be cool.  But when I dragged it onto a blank block diagram, all I got is a text label:
http://forums.ni.com/t5/image/serverpage/image-id/84118iC87C3DA23C0B55EF/image-size/original?v=mpbl-...
What am I missing?  Thanks.
Message 12 of 21
(1,354 Views)
crossrulz and jcarmody, your vi works great for a single numeric control.  How do I handle multiple numeric controls?  I created an event loop for each of the numeric controls.  But the mouse enter/leave events only fire up for the first numeric control.  And when entered in the first numeric control, the scroll takes turn changeing values of all numeric controls.  Please see atached.  Thanks.
Message 13 of 21
(1,349 Views)
crossruls and jcarmody, nevermind.  I neglected to edit the events handled by the additional loops.  Changed them to "Numeric 2" Mouse Enter, ... etc and it works fine.  But somehow in my main application, the mouse never leaves.  That's what prompted me to try the multi-numeric thing.
Message 14 of 21
(1,347 Views)
I think that's an issue with the way your browser handles dragging images.  Try saving the image to your computer and dragging it into the block diagram from there.  In Windows XP, I save snippets to my desktop then drag them onto the BD from there.
Jim
Message 15 of 21
(1,335 Views)
There's an issue with Firefox and, I believe, with Chrome.
There's a Quick Drop plugin available which is a useful workaround for this:
https://decibel.ni.com/content/docs/DOC-6229
Message 16 of 21
(1,331 Views)
Thanks Max, I tried with IE and it seem to work.  There is a version issue, but that's something else.
Message 17 of 21
(1,317 Views)
Thanks, you are right that it is with Chrome.  IE seems to work, but I only have LabVIEW 10.
Message 18 of 21
(1,315 Views)
@richard.koo wrote:
....  But somehow in my main application, the mouse never leaves.  That's what prompted me to try the multi-numeric thing.
I found out that once mouse enter fires up, the 1ms time out seem to tie up my cpu and no other events get serviced.  This actually makes all my front panel controls non-responsive.  I tried increasing the time out and at 120ms, it works.  I have a 1st gen quad core i7 Q720 1.6GHz.  My main vi is 5MB.  I have 10 event loops running before adding the event loop that services mouse scroll of 1 numeric control.  I have totally 20 numeric controls that I would like scroll capability.  Am I taxing the cpu excessively?  Anyway to optimize?  I don't mind upgrading my pc, but the target computer would be ordinary pcs and the app must work on them.
Message 19 of 21
(1,309 Views)
I would suggest changing to something like this so that there aren't nearly so many event structures.
Message 20 of 21
(1,306 Views)
