Use multicolumn listbox select functionality on table with non-numeric data
I have delimited data containing both numeric and string values that I want to display in a table. I would like the user to be able to select a single row of that data. This is built in functionality of the multicolumn listbox and not the table, but the MCLB seems to have a limit of only storing and displaying numeric data. I could manually add all of that functionality to the table control, but there has to be a better way. I'm open to using 3rd party libraries.
(1,282 Views)
Accepted by topic author Nokaroa
The displayed data of a MCLB is a 2D array of strings while the "value" is the selected row. It should be perfectly suitable for your purpose.
A formatted number is a string too.
If you still have problems, show us your code.
(1,257 Views)
I had no idea. Thank you
(1,243 Views)
