Use of Access database
I want to write a application that uses an Access Database. Actually I want to write data to and read data from a Database with Labview. Does anyone knows a library to control a Access Database. Or any other solutions.
Davy
(2,961 Views)
You've got several options. There is a shipping example that uses DDE to talk to an Access database. DDE sucks so you probably don't want to do that. There is ActiveX. There have been a lot of examples posted to the forum so you might want to do a search. ActiveX can be a real pain though. The nicest solution is to buy the Database Connectivity Toolkit from NI. It uses ADO/SQL to communicate to any database and hides a lot of complexity of learning SQL. There is also the free open source toolkit called LabSQL from Jeffrey Travis. This uses ADO/SQL to talk to any database. You'll need to learn SQL but that's not really that big a task.
(2,961 Views)
