Use of COM interfaces in LabVIEW 6.0.2
is it possible to use COM interfaces in LabVIEW 6.0.2? If it is possible could someone please send me an "manual" (short discription how to do it)
Regards Thomas
(3,077 Views)
If you want use COM in LabVIEW, you have 2 options:
1) COM with GUI - create on Front Panel ActiveX/ Container, click right button and select Insert ActiveX Object.
2) COM without GUI - create on Front Panel ActiveX/Automation Refnum, click right button and Select ActiveX. On diagram you have use Automation Open for opening of object and Automation Close for closing.
If your question is about how create COM object with LabVIEW - the answer is "You can't"
(3,077 Views)
Are you refering to Serial Interface?
If yes, the easiest way is to use Serial Compatibility vi(s) at
Functions Palette> Instrument I/O> I/O Compatibility> Serial Compatibility
Alternatively, you may wanna use VISA for Serial at
Functions Palette> Instrument I/O> Serial
Try to locate some example codes on Serial Interface as well.
brgds
ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,077 Views)
I think I am having brain-dead now... just write anything that's in my mind. This might be gone out of topic 😛
Ian F
依恩与LabVIEW
(3,077 Views)
I think my question was a little bit unclear. I want to use C++/Microsoft COM (Common Object Model) Interfaces.
Regards
Thomas
(3,077 Views)
Use the ActiveX open node on the diagram. Create a input constant for
the type specifier and browse to the typelib for the interface. LV
supports a subset of the datatypes that are needed for Automation
interfaces, but these are the most common anyway. From the open you can
connect Invoke and Property nodes to access the interface elements.
Greg McKaskle
(3,077 Views)
