Use of DAQ and BNC-2120
Hello there,
How can I use DAQ Assistance from labview to generate two different signal and output them from two analog output(AO1) and AO2 of BNC-2120? I tried but the DAQ fails.
(2,861 Views)
A BNC-2120 is only a connector block.  You can't do any analog input or output with it unless you connect it to a DAQ card.  So what DAQ device to you have it connected to?
Don't say you tried to do something and it failed without show us what you tried and in what way it failed.  Did it your LabVIEW program give an error message?  Did it fail by showing a big flash and then giving off a lot of smoke?
Give some details, error messages, attach your LabVIEW VI.
(2,860 Views)
