Use of LabVIEW6.1 runtime
My problem is the use of LabVIEW files, programmed with LabVIEW6.1. These files should be transferred to another PC and should run with a LabVIEW runtime version.
Is it necessary to create .exe files to run them? Standart LabVIEW-files can't be run on the System.
Thanks a lot
(3,554 Views)
You have double posted this question.
Look also here.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,554 Views)
Yes, you have to compile the vis to .exe (under windows) in order to be
able to use them with the runtime.
..vi's can only be run with the developement-version...
bye
Marco
(3,554 Views)
You can download the current runtime engine from ni.com. Install it on the PC that you are running on. Or you can create a exe that has no code, just a blank vi compiled into an exe and under the installer options you can include the runtime engine to be installed. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,554 Views)
Thanks for your help. I hoped there was a cheaper way 🙂
(3,554 Views)
Cheaper???
do you mean that you can't compile your vi's?
(3,554 Views)
Well, if I whant to compile my VI's I need a compiler. Hope I'm right. And this compiler is no freeware. So I have to get a compiler if I want to run my VI's with the LabVIEW runtime.
That's what I thought of.
(3,554 Views)
