Use of RTM in application
I have made an application from an excisting set of VI's. My VI makes use of a RTM. The application doesn't carry out this menu.
How can I make use of My RTM in an application?
(2,495 Views)
Can you describe how your vi is supposed to work in a little more detail, or if possible send a portion of code. If you Save as a development distribution it will include everything of relevance. Zipping the file will help if it is a little large.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,487 Views)
