Use of context menus of the Mixed Signal Graph causes application crash
Hi Rahul,
I've set up two virtual machines with Windows 7 Ultimate 64-bit MUI. On the first of them I've installed LabVIEW 2013 Professional development system, on the second - LabVIEW 2013 Runtime 32-bit and DSC Runtime 32-bit. I've built test application and installed it. Test application created on Windows 7 also crashes when I use context menu of cursor palette from remote panel. I think it is not platform-depending bug. Crash reports are in attached file.
Besides, when I open context menus from remote panel opened in IE on Windows 7 64-bit or Windows 8 64-bit, I can't see text of menu items, only transparent frame appears (inside red contours on pictures).
Message 11 of 16
(1,091 Views)
Hey Sectoid,
I am not sure at this time. Out of curiosity, what do you use the DSC runtime enginer for?
Rahul B.
Message 12 of 16
(1,076 Views)
Hi Rahul,
Application which I develop, uses OPC UA client functions.
Message 13 of 16
(1,063 Views)
Is there any relevant entry in the Windows Event Viewer System Log/Application Log? Something similar or related to DAbort 0x6E6C4057: RefCountedPtr-> pointee invalid?
The following link might be useful:
LabVIEW Internal Errors (Failure in XXX.c / XXX.cpp at line YYY)
http://digital.ni.com/public.nsf/allkb/01B186B5CEB1D07786256747000F4319
Message 14 of 16
(1,049 Views)
Hi Puchkov,
Only one record appears in logs when application crashes. Exported application log is attached.
Message 15 of 16
(1,033 Views)
At this moment I’m really busy, and have been unable to look at these logs; I’ll let other folks to participate and share more ideas.
Message 16 of 16
(1,021 Views)
