Use of control references within a loop
I use subVI's within a loop that process controls on the front panel. I have created references to those controls and pass them to the subVI's. I have 2 questions about them.
1) Does having the reference inside the loop have any memory impact (i.e. does it re-initialize the reference each iteration)? It is much cleaner to have the references inside the loop (less wiring).
2) Does a reference to a control obtained by right-clicking the control and selecting Create->Reference need to be closed?
Bill
(2,642 Views)
Hi Sweet William,
1) The control reference is a constant so it makes no difference if it is inside the loop.
2) Because the control reference is a constant the value doesn't change and therefore, closing the reference is not necessary.
See the attached link for more information on Control References.
http://www.ni.com/devzone/lvzone/dr_vi_archived4.htm
Chad Evans
(2,642 Views)
Thanks Chad
This is what I suspected and it is good to have it confirmed.
Bill
(2,642 Views)
