Use of edge detection in pattern matching algorithm?
Hello all,
                I work for a group at Texas A&M University researching two-phase flow in reactors.  We have been using IMAQ Vision and had a question regarding the use of edge detection in the pattern matching algorithm.  I had seen the webcast entitled “Algorithms that Learn: The Sum and Substance of Pattern Matching and OCR” (http://zone.ni.com/wv/app/doc/p/id/wv-705) and in the webcast it was mentioned that the pattern matching algorithm uses edge detection to, (as best I can tell), reduce the candidate list further and to perform subpixel location calculations.  However, I was wondering if this edge detection process is still performed if we do not use the subpixel location calculation (i.e. if we uncheck the “Subpixel Accuracy” check box)?  Also, if edge detection is performed in the pattern matching algorithm is it consistent with the method described in Chapter 13 of the Vison Concepts Manual (“Geometric Matching”)?  Finally, if edge detection is performed in a manner consistent with Chapter 13 of the manual, how does the geometric matching correlation number affect the correlation calculation that was performed in the previous steps?  Are they simply multiplied together?
Many thanks!
  -Aaron
(4,129 Views)
Hi Aaron,
What version of the Vision Development Module are you using?
And can you explain your application to us (how this is relevant, etc.?). Maybe we can get to the root of the problem that way.
Jeff | LabVIEW Software Engineer
(4,087 Views)
Jeff,
We are using Imaq Vision Builder 4, with the included pattern matching that can be accessed via the menus (i.e. we haven't created a custom VI or anything.)  We are using the software to locate bubbles during boiling experiments and want a deeper understanding of what is going on "behind the scenes" of the algorithm, as we may have to explain how it works later.  We have been able to determine most of what we need from the webcast I had previously mentioned, except for the use of edge detection in the pattern matching algorithm.
At the scales involved in our experiments, subpixel accuracy is really not needed and therefore we do not use it.  If edge detection is used in the pattern matching algorithm only to determine location with subpixel accuracy, then we do not really need to know how it works because we do not use that calculation.  Inversely, of course, if edge detection is used during pattern matching even without enabling subpixel accuracy, then we would like to have a fairly good understanding of the process.
I've read most of the section on geometric matching in the Vision Concepts Manual and wondered if the process described there for edge detection (or feature matching) was also used in the basic pattern matching algorithm?
To summarize, if edge detection is not used in the basic pattern matching algorithm without subpixel accuracy, then that is all I need to know.  If edge detection is used for pattern matching even without using the subpixel accuracy calculation, then we would like to learn more about how exactly it is used in the pattern matching algorithm.
We would really appreciate any help you could give us... we've been digging around on the NI website for a couple of weeks now trying to fit together all the pieces of the pattern matching puzzle.
Many thanks!
    Aaron
(4,068 Views)
I will have to look into what information I can provide and get back to you.
(4,043 Views)
