Use property information as a control
To all:
I would like get some help to use property information from a TDMS file.
what I want to do is get the sample clock rate from the file (which was previously written in another VI) and use that sample clock rate in the current vi without having to use another variable.
I can see the information just fine in a indicator panel, but how do I convert the "variant" data type to a double type, which I can use to feed into the reciprocal operation?
attached is a JPG with the bit of VI using the property
thanks for any instruction
A. Lopez
(3,106 Views)
Accepted by topic author lopez
Hi A. Lopez,
The "TDMS Get Properties.vi" has a input called "data type". You can wire a constant DBL numeric into that input and your property value output rather than being type variant will be of type DBL. You can also search LabVIEW's examples and find instances of this (for example "TDMS--Concurrent File Access example vi).
hope this helps.
Cheers,
--Russ
(3,081 Views)
Russ,
thanks for pointing out this feature.  I also found the variant to data function, which I used over the weekend before understanding I could wire a data type to the get property function.
AL
A. Lopez
(3,034 Views)
