Use "File Dialog" in a DLL
is there anything wrong in the example I send? I use app.vi to call a DLL function (implemented in dll.vi) which uses "File Dialog". The application hangs like if it would be waiting for file dialog but the dialog does not pop-up. Any Ideas?
David
(2,694 Views)
I'm not sure on what the issue is, but maybe these forum threads may solve your needs:
http://forums.ni.com/ni/board/message?board.id=170&message.id=67378&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=13178&requireLogin=False
Another idea would be to simply not use the file popup but a path control, tree control, etc...(or finally use a Win32 API function call for this, but you would need to use another programming language to create the DLL).
Jorge M.
(2,666 Views)
